Date/Time: Tue, 11 Feb 2025 18:07:44 +0000
Futures Option Trading
View Count: 612
[2020-09-16 04:31:56] |
User763002 - Posts: 27 |
Hello, I am looking to see if Denali supports futures options trading? AMP supports options trading, but I was told to reach out to Sierra about compatibility with the Denali Feed. Thank you Date Time Of Last Edit: 2020-09-16 12:42:10
[2020-09-16 10:36:00] |
Yes Sierra Chart does support futures options trading. You are using the Sierra Chart Order Routing Service and options trading is supported but not sure that your broker supports trading options on TT.
