Date/Time: Fri, 25 Sep 2026 14:58:09 +0000
[Programming Help] - Spreadsheet Persistent Variable Resetting Every New Trading Day
View Count: 823
[2020-09-16 04:10:40]
User355030 - Posts: 167
I currently have a persistent variable that plots a line. Is there a way to only make this line "active" for the trading day it triggered on? In other words, the persistent variable needs to zero out on a new calendar day (00:00:00).
@tomgilb
[2020-09-16 11:31:25]
Sawtooth - Posts: 4354
There is no one formula format that works for all persistent variable situations so, without more details, here is a way to identify a new day:
=INT(A3)>INT(A4)
Can you share the formula you are currently using? You can private message me if you like.
