Date/Time: Tue, 11 Feb 2025 20:13:06 +0000
problem with contract rollover during replay
View Count: 702
[2020-09-16 02:02:22] |
User476002 - Posts: 28 |
hi I'm having an issue during 'auto trade system replay backtest' where the year turns into a weird long number (like 15009 instead of 2019). This happens when the contract is supposed to change (I am using the "continuous futures contract - date rule rollover, back adjusted" setting in the chart. I have followed the instructions for uploading a chart. http://www.sierrachart.com/image.php?Image=1600221118924.png You can see the year is listed as 15009 after the June/Sept rollover. I have the same results with SC data or with my brokers data, and I have tried over a variety of time periods with the same result. Thank you for your help. |
[2020-09-16 05:21:24] |
We are checking on this now.
[2020-09-16 06:47:35] |
We cannot reproduce any problem with this. We want you to fully re-download the data for all contract months following these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data It must be some timestamp issue. But we are not clear specifically what is wrong. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-16 06:47:36] |
[2020-09-18 22:46:49] |
Thank you, I followed the instructions for deleting the data and it worked properly for one replay. But then the same issue returned, incorrect year after contract rollover. I opened my second installation of SC and have not had the issue. My second installation(on the same computer) is version 2131. The version I'm having the issue with is version 2159. Do you know of any settings that may be causing this issue? As far as I can tell they are set up the same. |
[2020-09-21 09:02:06] |
We want you to update to the current version and let us know if you still see the issue. Instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-21 09:02:16
