Date/Time: Wed, 12 Feb 2025 15:42:19 +0000
microsecond timestamp between different Denali feed servers
View Count: 1670
[2020-10-08 20:18:14] |
ejtrader - Posts: 688 |
Thank you. As I have a workaround - this is not a problem. But in general - the flag I have "Allow Support for Sierra Chart Data Feeds" being disabled should have taken precedence over whether I have the exchange enabled or not. The main issue here is - T&S is NOT in sync with the intraday file when intraday data gets downloaded on initial connection. T&S lags 10 minutes & 10 seconds compared to intraday file to begin with and eventually gets caught up. As is the delayed feed is really a wonderful idea and can live with this design - as I have a workaround for this and it is not that critical when T&S lags compared to intraday data. Thanks Date Time Of Last Edit: 2020-10-08 20:23:11
[2020-10-14 21:25:53] |
Team - Related to post #22 - if there are any auto triggered or manual historical downloads everything is working fine between instances/subinstances where real-time exchanges are enabled. But there is still a problem where delayed data is enabled. In the end - when the market is closed - the total number of trades per session doesn't match up unless delete and download data is used. There are additional records being added. As long there are no auto triggered download events - it matches up fine. Attached image 1 - This is from the instance - where there are few live exchanges and 1 delayed exchange - All the live exchange data - after the session close the number of trades matches up well. For the instrument(YM) with delayed data - there were discrepancies and were corrected after delete and download data for this specific instrument. Attached image 2 - This is the instance with delayed data for all the instruments. As you can see at the end of the session - all of them are incorrect (you can take image 1 as reference). Only way to correct them is to delete and download data. All of the historical download events triggered were automatic. Thanks Date Time Of Last Edit: 2020-10-23 16:32:06
[2020-10-23 13:46:55] |
SC Team - Wondering if you had a chance to look at this? Thanks |
[2020-10-30 21:39:14] |
SC Team - Any update on this issue?
[2020-11-04 01:06:38] |
SC Team - Any update you can provide on this?
