Date/Time: Fri, 04 Apr 2025 15:36:56 +0000
[Locked] - Updated Information Regarding Rithmic (Support will continue)
View Count: 4184
[2020-09-15 18:46:23]
We have previously announced, that we would be removing support for Rithmic in versions of Sierra Chart released after 2020-12-31 due to technical compatibility reasons. However, prior versions of Sierra Chart would continue to work with Rithmic.
For the time being the Rithmic bridge files for the interface to Rithmic are available here:
Rithmic Bridge Files
We have recently discussed with Rithmic an integration method using the open specification DTC protocol that Sierra Chart supports which will allow Sierra Chart to be compatible with Rithmic using the DTC protocol. So this is a good thing.
Therefore Rithmic will continue to be available after 2020-12-31.
If this new interface is not completed by then, we will continue to maintain support anyway for Rithmic after this date.
Date Time Of Last Edit: 2021-01-13 17:56:46
[2020-09-15 19:12:20]
User357195 - Posts: 123
I think Sierra Charts with a Rithmic feed is very good.
All I can ask for as a trader is to have a stable and fast platform; and, the rest is up to me to perform.
Thanks again to both Sierra Charts and to Rithmic.
Good trading to you.
Date Time Of Last Edit: 2020-09-15 19:12:39
