Date/Time: Tue, 11 Feb 2025 18:42:08 +0000
Keyboard shortcut to modify target based on entry offset?
View Count: 668
[2020-09-15 18:08:57]
User422433 - Posts: 18
Scenario:
Entry at 100, stop at 95, target 1 at 110, target 2 at 120.
Is there a way to set a shortcut to move target 2 to a certain tick offset from my entry? After my first target is hit, I may want to move my target 2 to 40 ticks from my entry instead of 20 ticks. I am aware of the Target Order Tick Up shortcut and also the right click menu option to move targets to price, but I would like to make custom keyboard shortcuts to move targets to a certain offset from entry. Is this possible?
[2020-09-15 20:48:03]
This is not directly supported you would have to custom program this which you certainly could do:
Advanced Custom Study Interface and Language (ACSIL)
[2020-09-15 23:52:38]
Are you aware of any existing example of an advanced custom study that modifies existing orders that I could use as a starting point?
[2020-09-16 10:42:15]
Yes have a look at the Trade Management by Study source code. More information is here:
Attached Orders: Study Controlled Targets and Stops
