Date/Time: Tue, 11 Feb 2025 18:09:10 +0000
Using 2nd Install
View Count: 493
[2020-09-15 16:23:04] |
User443403 - Posts: 9 |
I have package #5 (paid) thru my broker (AMP) - I have one install set up with AMP/CQG and that is working fine. I installed a second instance to use with my BitMex account - but every time I try to connect I get an not authorized message. First, is this allowed? And if so, what am I doing wrong? Thanks! |
[2020-09-15 20:53:27] |
Direct Sierra Chart Account When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
