Date/Time: Tue, 11 Feb 2025 18:14:49 +0000
[User Discussion] - How to use sub instances to reduce cpu load?
View Count: 1136
[2020-09-15 14:00:28]
BenjFlame - Posts: 335
what's the proper way to use sub instances to dilute cpu usage on multiple physical cores?
I have a multi core cpu with a core used 100% by sierra chart.
When I create a sub instance it does nothing.
Should I open charts on sub instance, in order for a new core to be used?
[2020-09-15 20:57:10]
Refer to:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
Yes.
