Date/Time: Thu, 10 Sep 2026 19:51:46 +0000
Volume Profiles
View Count: 766
| [2020-09-15 12:55:18] |
| User658309 - Posts: 2 |
Hi I am applying volume profiles to bespoke areas on the Dax chart. I would like to see at a glance the area that I have selected and have been trying to find somewhere where I can apply a light background tint to the active area, Please can you tell me if this is possible and how to do it. Thanks |
| [2020-09-15 14:21:46] |
| John - SC Support - Posts: 47839 |
The only option you have available to do this would be to use the Color Background Based on Alert Condition study, in which you would have to set the Alert to be the range of the times for which you want the coloring. Refer to the following documentation (the Color Background Based on Alert Condition just links to this documentation): https://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=245#Color_Bar_Based_on_Alert_Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
