Date/Time: Tue, 11 Feb 2025 18:34:56 +0000
Trade order lines not visible
View Count: 495
[2020-09-15 11:40:50] |
vish100 - Posts: 111 |
Hi, I have the 'trade--> show order and positions' enabled. I also have the 'Chart --> Chart Settings --> Advanced settings --> Align trade drawings text to right' ticked. I also have the 'Trade drawings left align' set to 100 However the order lines are not visible at all. I want them to show and extend all the way to the left. Can you help? Thanks Vish |
[2020-09-15 12:20:14] |
You need to disable this option: Chart Settings: Align Trade Drawings Text to Right (Chart >> Chart Settings >> Trading menu) Also refer to: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-15 12:23:31
[2020-09-15 12:26:02] |
No I want this option 'Chart --> Chart Settings --> Advanced settings --> Align trade drawings text to right' to be ENABLED. I want the text to be on right but order lines extend all the way to the left. |
[2020-09-15 12:28:08] |
There is no support for this.
