Date/Time: Mon, 25 Nov 2024 11:49:28 +0000
trend line not holding in reversal bar chart
View Count: 1208
[2014-02-06 12:10:34] |
MMX - Posts: 119 |
On my reversal bar chart, when drawing a trendline, if I terminate the trendline in the fill space it will not hold its position. Also, if you extend a trendline in the reversal bar chart it will not hold it's position. It's nothing that's real obvious at first, it changes slowly, but over 30 or 45 minutes it's very obvious the trendline has moved. If you terminate the trendline on or before the last bar, it will hold it's position (unless you extend it). I've never had this problem with minute charts and with minute charts I've always terminated my trendlines in the fill space and used extend drawing extensively.
[2014-02-06 17:13:49] |
Refer to this help topic: http://www.sierrachart.com/index.php?l=doc/helpdetails34.html We cannot provide further help with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
