Date/Time: Tue, 11 Feb 2025 18:07:46 +0000
Running slow
View Count: 726
[2020-09-15 00:36:42]
User516084 - Posts: 13
Sunday I ran a chart replay then later rolled over symbols. Since then, SC has been running slow. About a 5 second delay whenever I click on anything. I deleted all market depth data and the amount of days to load on all my charts. CPU is only running at 5% load and RAM at 15%. Doesn’t seem like a data lag. More like the program running slow. What else can I do?
Date Time Of Last Edit: 2020-09-15 01:16:24
[2020-09-15 01:55:05]
Try restarting Sierra Chart first. Although that really should not matter. This advice is more to correct any potential performance issue at the OS level affecting the process like memory management.
And then refer to help topic 30:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
[2020-09-15 02:32:49]
I’ll give some of these a try. It’s definitely not my pc. It has way more power than what SC demands. I haven’t changed anything study wise and it worked fine up until this weekend. It started running slow after I ran a chart replay from 7 days back on a chart with market depth in it.
