Date/Time: Tue, 11 Feb 2025 18:41:15 +0000
1 second chart
View Count: 1024
[2020-09-14 21:13:06] |
User651225 - Posts: 2 |
Are 1 second charts supported? I'm trying to figure out how to get things working on the trial and get data to test some things out to see if I want to use the service but I'm having trouble doing so. Can someone plz help?
[2020-09-14 22:04:02] |
Ackin - Posts: 1865 |
Chart >> Chart Settings Intraday Chart Bar Period >> Bar Period Type >> Days-Mins-Secs Per Bar Set 0-0-1 more: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TimePeriodPerBar |
[2020-09-14 22:32:25] |
Thank you. I'm struggling to get a data feed even though I have IB. I think it may be because I already have API's running on IB. Any recommendations?
[2020-09-15 00:08:55] |
It depends on what services. Even if you have IB I recommend getting an extension: Denali Exchange Data Feed. Denali Exchange Data Feed SC Support will definitely answer this for you .... wait for their answer. Date Time Of Last Edit: 2020-09-15 00:09:57
[2020-09-15 12:42:26] |
Tell us one of the symbols you want to receive data for from Interactive Brokers.
