Date/Time: Tue, 11 Feb 2025 17:28:32 +0000
Daily Volume Mismatch
View Count: 452
[2020-09-14 19:07:17] |
Tony - Posts: 549 |
Hi, I was looking at my ES mini chart today (Sep 14, 12pm Pacific), the Daily Volume on the Chart header showed the correct number, ~1.7M, but my 5000-volume-bar chart only has 200 bars for today, that comes to approx. 1.0M of daily volume. Not sure what I did wrong, please help. Thanks very much. |
[2020-09-14 19:15:01] |
There is a section about this on this page here: Differences With Data and Chart Bars Between Services / Connections / Chart Types: 43.7 - Comparing Daily Volume to Intraday Chart Bar Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-14 19:15:24
