Date/Time: Tue, 11 Feb 2025 17:39:35 +0000
Data Issues?
View Count: 478
[2020-09-14 16:39:48] |
Tom8toez - Posts: 29 |
My data feed continues to revert to "MESZ20_FUT_CME" instead of "MESU20_FUT_CME". The "Z" feed has issues with the volume ticks. I assume its is a December feed? When I manually change it and save to the "U" feed my volume ticks for September are ok. What should I do? |
[2020-09-14 17:01:39] |
John - SC Support - Posts: 37879 |
It sounds like you have the following setting enabled. Disable this: Chart Settings: Automatically Rollover Futures Symbol (Chart >> Chart Settings >> Symbol >> Symbol menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
