Date/Time: Mon, 25 Nov 2024 11:46:29 +0000
AMP/TTnet hold poition
View Count: 1222
[2014-02-06 11:27:22]
CaseyWang - Posts: 13
If use AMP/TTnet,trader can hold position to next day?!
AMP/Rithmic,too?!
[2014-02-06 18:00:55]
Yes. This is supported with any trading service Sierra Chart works with.
In the case of AMP/TTnet, you may need to use the Order Fill Calculated Position feature if the server does not actually report the overnight position. Refer to:
https://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#OrderFillCalculatedPosition
