Date/Time: Sat, 19 Sep 2026 04:15:54 +0000
Trading Account Has Changed
View Count: 694
[2020-09-14 16:38:40]
Michael1 - Posts: 5
I no longer have a trading account with AMP (119986). Instead, I am starting a new Combine with OneUp Trader. It is unclear how to substitute the new OneUp Account for the now deleted AMP account.
[2020-09-14 17:00:18]
John - SC Support - Posts: 47939
You just need to login with the credentials associated with the new account that you have setup.
Then, depending on whether your trading provider has changed, you will need to setup Sierra Chart to work with your new trading provider. You will need to find the specific provider in the following list, then go to the page for that provider and follow the Setup Instructions.
Supported Data and Trading Services: Supported Services
Finally, after you have that completed and you have charts from previously, then select this option to update the Symbols that are being used in your charts:
Edit Menu: Edit >> Translate Symbols To Current Service
