Date/Time: Tue, 11 Feb 2025 18:03:27 +0000
CQG Data Feed Keeps Disconnecting
View Count: 921
[2020-09-14 13:52:41] |
User331481 - Posts: 4 |
Hi there. I'm having an issue where my CQG data feed intermittently disconnects, which is extremely frustrating because I cannot trade effectively. I have ThinkOrSwim open and I don't have any disconnection issues with that platform. What do you recommend to fix this issue? Thanks, Brian |
[2020-09-14 16:26:48] |
John - SC Support - Posts: 37883 |
First, refer to this information specific to CQG: CQG Trading Platform Service: Frequent Server Disconnections when Using CQG Then refer to this more general information: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-14 18:29:34] |
You are also running a very old version of Sierra Chart. Update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-15 01:36:42] |
Thank you John, and SC Engineering team! I updated to the latest SC version. I'll take a look at the documentation links you provided as well, John.
