Date/Time: Tue, 11 Feb 2025 17:52:40 +0000
help me out in real time data feeding
View Count: 462
[2020-09-14 13:45:47]
User559616 - Posts: 1
hi dear support i hope you well
my question is does sierra chart still working with rithmic data feeder ?
can I use demo of rithmic for data feeding ?
can I use 2 times or 3 times demo rithmic credintals for live data feeding ?
what is other exchanges that give me data feeding as trial ?>
how much sc data feeding has delay ? 10 minutes and 10 seconds from local zone ?
[2020-09-14 16:25:09]
John - SC Support - Posts: 37882
We do not recommend using Rithmic with Sierra Chart at this time, as we will most likely be ending support for Rithmic in the coming months. Refer to the information here:
Regarding Rithmic (Our Final Post on this Subject)
For a trial of Sierra Chart, the best option for data is to use the Delayed Exchange Data Feed. This gives the data from the CME Group at no extra cost and the data is streaming, so it acts in all respects like like data, but that data is actually 10 minutes and 10 seconds delayed. Refer to the information here:
