Date/Time: Tue, 11 Feb 2025 17:54:18 +0000
Unable to update my Custom Study DLL while Sierra Chart is running?
View Count: 604
[2020-09-14 12:02:31] |
mbilyanov - Posts: 62 |
Hi, I'm working on a custom study and I would like to be able to update the DLL as Sierra Chart is running. Right now, the code is very simple and I have the sc.FreeDLL=1;
directive in there, which I suppose is designed to let me update and test my DLL on the go. However, right now, whenever I'm trying to overwrite the current version inside the `./Data` folder, I'm getting an error indicating that the file is in use. What is the solution to that problem? Do I really need to restart SC everytime I'm building a new DLL? I'm using Visual Studio. |
[2020-09-14 12:29:22] |
Ackin - Posts: 1865 |
just to "FreeDLL" sc.FreeDLL is no longer required as of version 1836 and higher. As of that version, setting this has no effect.
[2020-09-14 16:18:40] |
John - SC Support - Posts: 37883 |
Refer to the documentation starting here and the 2 items after it: Analysis Menu: Release All DLLs and Deny Load (Build Advanced Custom Studies DLL Window >> Build) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
