Date/Time: Tue, 11 Feb 2025 18:04:09 +0000
ZZ Data Does Not Export
View Count: 836
[2020-09-13 23:20:23] |
User240019 - Posts: 112 |
1. Study is set for additional output 2. subgraphs say to include in study 3. eliminated all other studies and it still doesn't work, to answer for precendence. Attached chartbook. What can I do to get the text labels to output? |
[2020-09-14 14:27:30] |
John - SC Support - Posts: 37883 |
We are not sure exactly what your question is. But, if you are wondering why your spreadsheet does not show the Text Labels, that is because you need to turn them on in the Zig Zag study itself first. Then they will show as a number that represents the label. Refer to the information here: Zig Zag: Text Labels Subgraph Description If you are asking about the volumes that you have displayed, then you just need to coordinate the lines where there is a Reversal Price to the Accumulated Volume. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-15 13:08:35] |
OK, thank you. I was looking to see the text labels show in the spreadsheet. Thank you for the help.
