Date/Time: Fri, 11 Sep 2026 16:26:14 +0000
[User Discussion] - Convert HMS to MInutes
View Count: 1154
[2020-09-13 11:03:52]
Graham - Posts: 44
Struggling to work this out using the SDDateTime() functionality.
How can I convert the total time in HMS to just minutes. SCDateTime can extract any part of the time but I need to convert a variable that could be HMS or just MS to Minutes only.
As an example, if the variable returns 01:56:00 (HMS) what would the code be to convert that to Minutes only, resulting in: 116.
Thanks in advance.
[2020-09-13 12:34:46]
User907968 - Posts: 883
If you already have an SCDateTime variable, for minutes you could use GetTimeInSeconds() / 60
Working with the SCDateTime Variables and Values: GetTimeInSeconds()
int Minutes = dateTime.GetTimeInSeconds() / 60;
If you first need to construct the SCDateTime variable from HMS (or just MS) you could use the appropriate constructor.
Working with the SCDateTime Variables and Values: SCDateTime() Constructors
SCDateTime(int Hour, int Minute, int Second, int Millisecond);
SCDateTime dateTime(H, M, S, 0);
