Date/Time: Tue, 11 Feb 2025 14:15:01 +0000
Deactivate Sierra chart
View Count: 553
[2020-09-13 03:28:10] |
lisic24 - Posts: 3 |
Hello, I'm South Korean, So please excuse my english. I'm planning to change my desktop. And I know that Sierra chart can run only 2 computers If I'm not paying additional fee for other seats. So, My question is, How to deactivate Sierra chart in my old Computer to avoid issues? Thank you. Date Time Of Last Edit: 2020-09-13 03:32:50
[2020-09-13 03:35:49] |
This is not a concept you need to be concerned with. You just need to be sure that Sierra Chart is not running at the same time on more than two computers. This is all.
[2020-09-13 03:37:22] |
Thanks !
