Date/Time: Fri, 02 Oct 2026 07:25:38 +0000
ACSIL study needs to be recompiled on last Sierra Chart version 2164
View Count: 1172
[2020-09-12 07:20:05]
sugart - Posts: 25
After updating to the latest Sierra Chart version 2164, every time I run an ACSIL study it is has to be recompiled again. Why is this? Why do I have to recompile all my studies again? Is there any solution to this?
[2020-09-14 11:06:01]
This does not make sense to us. There is no requirement for this as long as the study has been recompiled for Version 2155 and higher:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2156
We would need you to determine the reason for this problem as we have absolutely no idea.
Date Time Of Last Edit: 2020-09-14 11:07:02
[2020-09-14 14:19:46]
sugart - Posts: 25
Please see the attached file. All my studies need to be recompiled. They were running fine before. Actually, since it is your software and your updated version, I hoped that you would know why.
Date Time Of Last Edit: 2020-09-14 14:21:41
[2020-09-14 14:25:08]
sugart - Posts: 25
File attached
imageSierra Chart dlls need to be recompiled in version 2164.JPG / V - Attached On 2020-09-14 14:24:37 UTC - Size: 126.3 KB - 340 views
[2020-09-14 14:47:35]
ForgivingComputers.com - Posts: 1239
Could it be you are downloading a new (old) copy of the DLL from the Sierra server on startup? If you didn't rename the DLL with _2151 then you could be see the old file.
