Date/Time: Mon, 25 Nov 2024 11:47:07 +0000
Two Chart Regions split Vertically
View Count: 1385
[2014-02-05 20:04:16] |
Profile Trader - Posts: 174 |
In the image section the first image dated 9-19-2013 there is a candle chart to the left and then a volume chart to the right. Can someone advise how to do this? what section should I be reading about to learn how to do this? Thanks, Doug |
[2014-02-06 00:52:39] |
There is no attached image here.
[2014-02-06 02:33:57] |
I am referencing the image posted in the User Image Gallery
[2014-02-06 04:04:18] |
Could you provide us a link to it here: Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-06 04:05:32] |
http://www.sierrachart.com/index.php?l=doc/Image_gallery.php |
