Date/Time: Sun, 27 Sep 2026 15:58:39 +0000
Status Bar
View Count: 1637
| [2020-09-11 17:11:58] |
| GreyLock58 - Posts: 173 |
Is there a way to enlarge the button so all the info shows? I have attached a screen shot.
| Attachment Deleted. |
| [2020-09-11 17:35:48] |
| John - SC Support - Posts: 48028 |
There is not a way to change the size of the status bar.
| [2020-09-11 17:58:24] |
O.K. I tried to reduce the size of the font using the directions given in Graphic settings for Text Windows, but that does not work. I figure if I can reduce the font size, then I should be able to see the rest of the Status Bar info. Please advise.
| [2020-09-12 02:35:57] |
| User90125 - Posts: 715 |
Or just give us a way to STRETCH out the length of the status bar. Would be most useful to have this functionality. |
| [2020-09-12 21:36:44] |
So, if the status bar cannot be changed, then why include info on it that cannot be read? As soon as BR: becomes a large number it runs off the edge of the Status Bar and the DL: number becomes invisible.
| [2020-09-13 02:58:57] |
There is a new setting for this: General Settings Window: Status Bar Width in Characters (Global Settings >> General Settings >> GUI >> Application GUI) (At the bottom of the page) But we see it is not doing anything so we need to look into this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
