Date/Time: Tue, 11 Feb 2025 14:22:50 +0000
Volume Profile Bars Length Relative To All Visible Profile
View Count: 626
[2020-09-11 14:48:48] |
wiivanil - Posts: 12 |
Hi, is it possible to implement this setting? I'm using the Color Code Bar and I'd like the colors to be calculate on all the visible bars without crushing the volume on all bars. In the images I'm using 2 different studies VbP to see the volumes in the bars that have less volume. It would be great also if the calculating instead the visible bars would be for all day/session. Grazie Ivan |
Attachment Deleted. ![]() ![]() |
