Date/Time: Tue, 11 Feb 2025 17:24:43 +0000
[Locked] - Historical Data errors! - Using Instances
View Count: 1054
[2020-09-11 12:57:05]
User316362 - Posts: 210
Getting "red" Download failed Message.
Error Downloading historical Intraday data for ESZ20.... Historical Data logon error: Data files folder not set for service code :DTCSubInstance.
Also, it seems that I have to rollover in each instance shouldn't i be able to just do it in any instance or the main one? Also the New symbol setting in rollover message window is not on the "next" contract but the same contract..i have to pick it manually.
Also getting "Volume of 0" messages in message log...see attached file
Date Time Of Last Edit: 2020-09-11 13:21:23
Private File
Private File
[2020-09-11 13:43:33]
John - SC Support - Posts: 37875
In your Main Instance of Sierra Chart go to the chart for ESZ20 and select Edit >> Delete All Data and Download. Wait for the data to be redowloaded. If this is a Continuous Contract, then just select the data for the ESZ20 contract.
Then go to the sub-instance for the same symbol and do the same thing in the sub-instance (Edit >> Delete All Data and Download).
Refer to the information here for redownloading the data:
Edit Menu: Edit >> Delete All Data And Download
The volume message is because you are using a Continuous contract with Volume based rollover, but there is no data back to 2000. Refer to the information here for how much data is available from Sierra Chart:
Sierra Chart Historical Data Service: What is Included
Just change the amount of data you are loading to not go back that far and you should no longer get those messages. Refer to the information here:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad
[2020-09-12 13:24:54]
thanks. The volume messages make complete sense and i corrected that.
I am also on v2164.
However, i did "Edit >> Delete All Data and Download" on the main and sub-instances, i still get the same Instance error shown in post #1 above. it flashes on and then goes away on the sub-instances only. The data looks fine.
Date Time Of Last Edit: 2020-09-12 14:04:42
[2020-09-12 17:39:59]
BTW i have two traders using the same instance setup and chartbooks but a different broker. They do not see the message. I use Dorman and they use TransAct. Just in case this might be a lead. I believe it's different symbol names
[2020-09-12 19:07:28]
User100912 - Posts: 104
I have this issue: Data files folder not set for service code: DTCSubInstance
Sorry for duplicate post.
[2020-09-12 21:42:28]
What version are you noticing this with? We are not able to reproduce this.
After looking into this, we do not even see how technically this could occur unless Global Settings >> General Settings >> Data Files Folder is not set. Check that.
[2020-09-12 22:05:07]
We are still looking into this. Still not able to reproduce but we have some better understanding of it now.
[2020-09-12 23:35:53]
I think they are set correctly. Also, nothing was touched other than an update to the latest version 2164 and of course there was a rollover to the "z" contract when the error message started to occur. As mentioned before an "Edit\Delete all data and download" in all instances did not correct the error message.
For the main/primary instance it is set to "C:\SierraChart\Data\"
For instance 2 the data files folder is set to "C:\SierraChart\SierraChartInstance_2\Data\"
for instance 3 it is "C:\SierraChart\SierraChartInstance_3\Data\"
Date Time Of Last Edit: 2020-09-12 23:38:50
[2020-09-13 02:41:49]
We want you to update to the current version 2166 and let us know if you still see the issue. Instructions:
[2020-09-13 15:26:09]
I updated to version 2166. I no longer see the error message.
Thanks so much for your support.
[2020-09-13 22:58:00]
Ok there is live data now. While the error message went away. I now have a problem getting live data to Instance "3".
Basically I have a main instance (1), and Instance 2 , and Instance 3.
It's like the instances are now being treated as total Sierra connections instead of subinstances in one connection and subInstance3 is being denied live data.
The message log is weird also it's talking about max connections and SC Data - All services with I'm using DTC subinstance service for instance 3. The main instance uses the SC Futures Order/Routing/Data. I do have service level 5 and also i have only used "Used up a total of 215 out of 30000" historical records.
Getting errors like "SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:48:06.279" ............which makes no sense for one sierra connection (install)
with two additional subinstances.
As an experiment I closed subInstance2 and now SUbinstance3 is working live. So seems like subinstances are now being treated as Sierra Connections as if i had more than two systems running. WHen I then brough back up the subInstance2 it now is the one without a live connection. Also i rolled back to 2164 and this issue goes away but of course the error message returns as originally described.
My once working instance 3 is useless at this point.
Here is my message log for instance 3 that may help you. This message log looks nothing like the other two instances.
____________________________________________________________________________________________________
Reading Internal Order ID file. | 2020-09-13 18:45:20.971
Reading Trade Orders file. | 2020-09-13 18:45:21.124
Reading Trade Positions file. | 2020-09-13 18:45:21.124
Reading Account Balance file. | 2020-09-13 18:45:21.125
UDPListener (1792). Port 57841 | Listening on UDP port 57841. | 2020-09-13 18:45:21.151
Software version: 2166 64-bit | 2020-09-13 18:45:21.151
OpenGL enabled | 2020-09-13 18:45:21.151
Primary Thread ID: 9568 | 2020-09-13 18:45:21.151
Usage end date: 2020-11-19 | 2020-09-13 18:45:21.151
Enabled for: Advanced Features 2. | 2020-09-13 18:45:21.151
Enabled for: Sierra Chart Historical Data Service. | 2020-09-13 18:45:21.151
Enabled for: Denali Real-Time Exchange Data Feed. | 2020-09-13 18:45:21.151
Enabled for: Delayed Denali Real-Time Exchange Data Feed. | 2020-09-13 18:45:21.151
Enabled for exchange2: CME | 2020-09-13 18:45:21.151
Allow Support for Sierra Chart Data Feeds is enabled. | 2020-09-13 18:45:21.151
Current selected Data/Trading service: DTC - Sub Instance | 2020-09-13 18:45:21.151
Custom symbol settings values: disabled | 2020-09-13 18:45:21.151
Chart Update Interval: 500 | 2020-09-13 18:45:21.151
Intraday Data Storage Time Unit: 0 | 2020-09-13 18:45:21.151
Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2020-09-13 18:45:21.152
2020-09-13 18:45:21 Local computer time | 2020-09-13 18:45:21.152
2020-09-13 22:45:21 Local computer time in UTC | 2020-09-13 18:45:21.152
2020-09-13 18:45:21 Local computer time in SC Time Zone | 2020-09-13 18:45:21.152
2020-09-13 22:45:21 Server time in UTC | 2020-09-13 18:45:21.152
Local computer UTC time and Server UTC time difference: 1 seconds. | 2020-09-13 18:45:21.152
Program path: C:\SierraChart\SierraChartInstance_3\ | 2020-09-13 18:45:21.152
Data Files path: C:\SierraChart\SierraChartInstance_3\Data\ | 2020-09-13 18:45:21.152
OS Version Number: 10.0 | 2020-09-13 18:45:21.152
Locale Setting: C | 2020-09-13 18:45:21.152
DLLs: FluidityTrader-copy.dll, FluidityTrader_64.dll, HamptonStudies_64.dll, HamptonTrader_64.dll, Statistics.dll, TestBed.dll, TestBed2.dll, TestBed2_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2020-09-13 18:45:21.154
Allowed protected custom studies: HamptonStudies, HamptonTrader | 2020-09-13 18:45:21.154
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:45:21.172
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2020-09-13 18:45:21.295
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2020-09-13 18:45:21.295
Received 5 login tokens. | 2020-09-13 18:45:21.594
Files to Open on Start up | Opening file: HS_Daily.Cht | 2020-09-13 18:45:24.737
Loading DLL C:\SierraChart\SierraChartInstance_3\Data\HamptonStudies_64.dll | 2020-09-13 18:45:24.742
ESZ20_FUT_CME [CV] Daily #1 | Reloading chart. | 2020-09-13 18:45:24.831
ESZ20_FUT_CME [CV] Daily #1 | Performing historical Daily data download for symbol ESU20 starting at last date in file. | 2020-09-13 18:45:24.937
Starting DelayedDownloadMonitoringTimer | 2020-09-13 18:45:24.937
Starting HDTimeoutTimer | 2020-09-13 18:45:24.937
Added historical Daily data request for ESU20 to the queue. | 2020-09-13 18:45:24.937
Triggering next historical data download in queue. | 2020-09-13 18:45:24.937
ESZ20_FUT_CME [CV] Daily #1 | Performing historical Daily data download for symbol ESZ20_FUT_CME starting at last date in file. | 2020-09-13 18:45:24.938
Added historical Daily data request for ESZ20_FUT_CME to the queue. | 2020-09-13 18:45:24.938
ESZ20_FUT_CME [CV] Daily #1 | Waiting for historical downloads to complete with the IDs: 1, 2, | 2020-09-13 18:45:26.201
ESZ20_FUT_CME [CV] 7 Day #3 | Reloading chart. | 2020-09-13 18:45:26.276
ESZ20_FUT_CME [CV] 7 Day #3 | Limiting the number of years to load data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:45:26.276
ESZ20_FUT_CME [CV] 7 Day #3 | Limiting the number of years to download historical data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:45:26.276
ESZ20_FUT_CME [CV] 7 Day #3 | Performing historical Daily data download for symbol ESZ20 starting at last date in file. | 2020-09-13 18:45:26.539
Added historical Daily data request for ESZ20 to the queue. | 2020-09-13 18:45:26.539
ESZ20_FUT_CME [CV] 7 Day #3 | Waiting for historical downloads to complete with the IDs: 3, | 2020-09-13 18:45:27.182
ESZ20_FUT_CME [CV] 1 Day #4 | Reloading chart. | 2020-09-13 18:45:27.223
ESZ20_FUT_CME [CV] 1 Day #4 | Limiting the number of years to load data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:45:27.223
ESZ20_FUT_CME [CV] 1 Day #4 | Limiting the number of years to download historical data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:45:27.223
Files to Open on Start up | Opening file: HS_TPO.cht | 2020-09-13 18:45:28.030
ESZ20_FUT_CME [CV] #2 | Reloading chart. | 2020-09-13 18:45:28.083
ESZ20_FUT_CME 3 Min #1 | Reloading chart. | 2020-09-13 18:45:28.236
HD Request # 1 | Downloading Historical Daily chart data for ESU20. Starting date: 2020-09-10. Service: DTCSubInstance | 2020-09-13 18:45:28.253
HD Request # 1 | Using server: 127.0.0.1 port 11098 | 2020-09-13 18:45:28.253
Socket (1) | Creating socket. | 2020-09-13 18:45:28.253
Socket (1) | Connecting to IP: 127.0.0.1. | 2020-09-13 18:45:28.253
HD Request # 1 | Setting DTC encoding to Binary VLS | 2020-09-13 18:45:28.265
HD Request # 1 | Sending historical data logon request message. | 2020-09-13 18:45:28.265
HD Request # 1 | Requesting historical Daily data starting at 2020-09-10. | 2020-09-13 18:45:28.265
HD Request # 1 | Decompressing data. | 2020-09-13 18:45:28.266
HD Request # 1 | Receiving historical Daily data for ESU20 starting at 2020-09-10 | 2020-09-13 18:45:28.269
HD Request # 1 | Writing historical Daily data to the file ESU20.dly | 2020-09-13 18:45:28.269
Socket (1) | CloseSocket call. | 2020-09-13 18:45:28.271
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:45:28.271
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:45:28.271
Socket (1) | Socket gracefully closed by remote side. | 2020-09-13 18:45:28.272
Socket (1) | Closed. | 2020-09-13 18:45:28.272
Historical data download thread signaled to stop. | 2020-09-13 18:45:28.285
HD Request # 1 | Received 3 records from 2020-09-10 00:00:00 to 2020-09-14 00:00:00 (5.0 days) and wrote 3 records for ESU20 | 2020-09-13 18:45:28.285
HD Request # 1 | Completion time: 0s | 2020-09-13 18:45:28.286
HD Request # 1 | Daily data download complete for ESU20. Unique request ID: 1 | 2020-09-13 18:45:28.286
Removing historical data download ID 1. | 2020-09-13 18:45:28.286
Triggering next historical data download in queue. | 2020-09-13 18:45:28.286
Mapping ESZ20_FUT_CME to ESZ20. Service code: cme | 2020-09-13 18:45:28.286
HD Request # 2 | Downloading Historical Daily chart data for ESZ20_FUT_CME. Starting date: 2020-09-10. Service: DTCSubInstance | 2020-09-13 18:45:28.287
HD Request # 2 | Using server: 127.0.0.1 port 11098 | 2020-09-13 18:45:28.287
Socket (1) | Creating socket. | 2020-09-13 18:45:28.287
Socket (1) | Connecting to IP: 127.0.0.1. | 2020-09-13 18:45:28.288
HD Request # 2 | Setting DTC encoding to Binary VLS | 2020-09-13 18:45:28.297
HD Request # 2 | Sending historical data logon request message. | 2020-09-13 18:45:28.297
HD Request # 2 | Requesting historical Daily data starting at 2020-09-10. | 2020-09-13 18:45:28.298
HD Request # 2 | Decompressing data. | 2020-09-13 18:45:28.299
HD Request # 2 | Receiving historical Daily data for ESZ20_FUT_CME starting at 2020-09-10 | 2020-09-13 18:45:28.300
HD Request # 2 | Writing historical Daily data to the file ESZ20_FUT_CME.dly | 2020-09-13 18:45:28.300
Socket (1) | CloseSocket call. | 2020-09-13 18:45:28.302
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:45:28.302
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:45:28.302
Socket (1) | Socket gracefully closed by remote side. | 2020-09-13 18:45:28.302
Socket (1) | Closed. | 2020-09-13 18:45:28.302
Historical data download thread signaled to stop. | 2020-09-13 18:45:28.309
HD Request # 2 | Received 3 records from 2020-09-10 00:00:00 to 2020-09-14 00:00:00 (5.0 days) and wrote 3 records for ESZ20_FUT_CME | 2020-09-13 18:45:28.309
HD Request # 2 | Completion time: 0s | 2020-09-13 18:45:28.309
HD Request # 2 | Daily data download complete for ESZ20_FUT_CME. Unique request ID: 2 | 2020-09-13 18:45:28.309
Removing historical data download ID 2. | 2020-09-13 18:45:28.309
Triggering next historical data download in queue. | 2020-09-13 18:45:28.310
HD Request # 3 | Downloading Historical Daily chart data for ESZ20. Starting date: 2020-09-10. Service: DTCSubInstance | 2020-09-13 18:45:28.311
HD Request # 3 | Using server: 127.0.0.1 port 11098 | 2020-09-13 18:45:28.311
Socket (1) | Creating socket. | 2020-09-13 18:45:28.311
Socket (1) | Connecting to IP: 127.0.0.1. | 2020-09-13 18:45:28.312
ESZ20_FUT_CME [CV] Daily #1 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-09-13 18:45:28.321
HD Request # 3 | Setting DTC encoding to Binary VLS | 2020-09-13 18:45:28.321
HD Request # 3 | Sending historical data logon request message. | 2020-09-13 18:45:28.321
HD Request # 3 | Requesting historical Daily data starting at 2020-09-10. | 2020-09-13 18:45:28.322
ESZ20_FUT_CME [CV] Daily #1 | Reloading chart. | 2020-09-13 18:45:28.322
HD Request # 3 | Data is being downloaded from a remote source. Download will start when this is done. | 2020-09-13 18:45:28.323
Added historical Intraday data request for ESZ20_FUT_CME to the queue. | 2020-09-13 18:45:28.599
Intraday data recording state for symbol ESZ20_FUT_CME is set to download 'Pending'. | 2020-09-13 18:45:28.599
Triggering next historical data download in queue. | 2020-09-13 18:45:28.599
ESZ20_FUT_CME [CV] Daily #1 | Reloading chart. | 2020-09-13 18:45:28.825
HD Request # 3 | Decompressing data. | 2020-09-13 18:45:30.314
HD Request # 3 | Receiving historical Daily data for ESZ20 starting at 2020-09-10 | 2020-09-13 18:45:30.315
HD Request # 3 | Writing historical Daily data to the file ESZ20.dly | 2020-09-13 18:45:30.316
Socket (1) | CloseSocket call. | 2020-09-13 18:45:30.318
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:45:30.318
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:45:30.318
Socket (1) | Socket gracefully closed by remote side. | 2020-09-13 18:45:30.319
Socket (1) | Closed. | 2020-09-13 18:45:30.319
Historical data download thread signaled to stop. | 2020-09-13 18:45:30.566
HD Request # 3 | Received 3 records from 2020-09-10 00:00:00 to 2020-09-14 00:00:00 (5.0 days) and wrote 3 records for ESZ20 | 2020-09-13 18:45:30.566
HD Request # 3 | Completion time: 2s | 2020-09-13 18:45:30.566
HD Request # 3 | Daily data download complete for ESZ20. Unique request ID: 3 | 2020-09-13 18:45:30.566
Removing historical data download ID 3. | 2020-09-13 18:45:30.566
Triggering next historical data download in queue. | 2020-09-13 18:45:30.566
HD Request # 4 | Downloading Intraday chart data for ESZ20_FUT_CME to the file ESZ20_FUT_CME.scid. Service: cme | 2020-09-13 18:45:30.567
Enabling compression for file: C:\SierraChart\SierraChartInstance_3\Data\ESZ20_FUT_CME.scid. This may take a while. | 2020-09-13 18:45:30.567
HD Request # 4 | Download start date-time: 2020-09-13 18:42:48.000 | 2020-09-13 18:45:30.567
HD Request # 4 | Using server: ds23.sierracharts.com port 10150 | 2020-09-13 18:45:30.567
Socket (1) | Creating socket. | 2020-09-13 18:45:30.567
Socket (1) | Connecting to IP: 216.1.90.130. | 2020-09-13 18:45:30.567
ESZ20_FUT_CME [CV] 7 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-09-13 18:45:30.581
ESZ20_FUT_CME [CV] 7 Day #3 | Reloading chart. | 2020-09-13 18:45:30.582
HD Request # 4 | Setting DTC encoding to Binary VLS | 2020-09-13 18:45:30.639
HD Request # 4 | Sending historical data logon request message. | 2020-09-13 18:45:30.639
HD Request # 4 | Requesting Intraday data. Start date-time: 2020-09-13 18:42:48. Record interval: 0. Symbol: ESZ20 | 2020-09-13 18:45:30.669
HD Request # 4 | Decompressing data. | 2020-09-13 18:45:30.699
HD Request # 4 | Receiving Intraday data for ESZ20_FUT_CME starting at 2020-09-13 18:42:48.107000 | 2020-09-13 18:45:30.700
Socket (1) | CloseSocket call. | 2020-09-13 18:45:30.701
Socket (1) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:45:30.701
Socket (1) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:45:30.701
Socket (1) | Socket gracefully closed by remote side. | 2020-09-13 18:45:30.752
Socket (1) | Closed. | 2020-09-13 18:45:30.752
HD Request # 4 | Historical data for ESZ20_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2020-09-13 18:45:30.756
Historical data download thread signaled to stop. | 2020-09-13 18:45:30.756
HD Request # 4 | Timestamp of first Intraday data file record written: 2020-09-13 18:42:48.107003 | 2020-09-13 18:45:30.756
HD Request # 4 | Received 319 records from 2020-09-13 18:42:48.107 to 2020-09-13 18:45:28.521 (2.7 minutes) and wrote 319 records for ESZ20_FUT_CME | 2020-09-13 18:45:30.756
HD Request # 4 | Completion time: 0s | 2020-09-13 18:45:30.756
HD Request # 4 | Intraday data download complete for ESZ20_FUT_CME. Unique request ID: 4 | 2020-09-13 18:45:30.756
Removing historical data download ID 4. | 2020-09-13 18:45:30.756
HD Request # 4 | Enabling Intraday chart updating for symbol. | 2020-09-13 18:45:30.756
Triggering next historical data download in queue. | 2020-09-13 18:45:30.756
DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 | 2020-09-13 18:45:30.765
DTC Client socket (1) | Creating socket. | 2020-09-13 18:45:30.765
DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2020-09-13 18:45:30.765
DTC - Sub Instance | Network connection to server complete. | 2020-09-13 18:45:30.777
DTC - Sub Instance | Starting socket receive thread. | 2020-09-13 18:45:30.777
DTC - Sub Instance | Sending encoding request to server: Binary VLS | 2020-09-13 18:45:30.777
DTC - Sub Instance | Setting DTC encoding to Binary VLS | 2020-09-13 18:45:30.780
DTC - Sub Instance | Sending logon request message. | 2020-09-13 18:45:30.780
DTC - Sub Instance | Received logon response. | 2020-09-13 18:45:30.787
DTC - Sub Instance | Server Name: SC DTC Server. | 2020-09-13 18:45:30.787
DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:45:30.787
DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures.dtc.trading|SymbolSettings=sc_futures.dtc.trading. | 2020-09-13 18:45:30.787
DTC - Sub Instance | Trading is supported. | 2020-09-13 18:45:30.787
DTC - Sub Instance | Order cancel and replace is supported. | 2020-09-13 18:45:30.787
DTC - Sub Instance | OCO Orders supported. | 2020-09-13 18:45:30.787
DTC - Sub Instance | Bracket Orders supported. | 2020-09-13 18:45:30.787
DTC - Sub Instance | Connected to server complete. | 2020-09-13 18:45:30.787
Triggering next historical data download in queue. | 2020-09-13 18:45:30.787
Mapping ESZ20_FUT_CME to ESZ20. Service code: cme | 2020-09-13 18:45:30.795
SC Data - All Services | Starting real-time market data updates for: ESZ20_FUT_CME (ESZ20). ID: 1 Service code: cme | 2020-09-13 18:45:30.795
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:45:30.795
SC Data - All Services | Requesting security definition data for: ESZ20_FUT_CME (ESZ20). ID: 1 | 2020-09-13 18:45:30.795
Added historical Intraday data request for ESZ20_FUT_CME to the queue. | 2020-09-13 18:45:30.795
Intraday data recording state for symbol ESZ20_FUT_CME is set to download 'Pending'. | 2020-09-13 18:45:30.795
Triggering next historical data download in queue. | 2020-09-13 18:45:30.795
Delaying start of download for ESZ20_FUT_CME | 2020-09-13 18:45:30.795
DTC Client socket (2) | Creating socket. | 2020-09-13 18:45:30.795
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:45:30.795
SC Futures Order Routing/Data | Received security definition for symbol ESZ20_FUT_CME | 2020-09-13 18:45:30.797
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:45:30.827
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:45:30.827
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:45:30.827
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:45:30.902
SC Data - All Services | Sending logon request message. | 2020-09-13 18:45:30.902
ESZ20_FUT_CME [CV] 7 Day #3 | Reloading chart. | 2020-09-13 18:45:31.077
ESZ20_FUT_CME [CV] 7 Day #3 | Limiting the number of years to load data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:45:31.077
ESZ20_FUT_CME [CV] 7 Day #3 | Limiting the number of years to download historical data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:45:31.077
ESZ20_FUT_CME [CV] 7 Day #3 | Performing historical Daily data download for symbol ESU20_FUT_CME starting at last date in file. | 2020-09-13 18:45:31.187
Added historical Daily data request for ESU20_FUT_CME to the queue. | 2020-09-13 18:45:31.187
Triggering next historical data download in queue. | 2020-09-13 18:45:31.187
ESZ20_FUT_CME [CV] 7 Day #3 | Waiting for historical downloads to complete with the IDs: 6, | 2020-09-13 18:45:32.009
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:45:32.009
SC Data - All Services | Received logon response. | 2020-09-13 18:45:32.009
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:45:32.009
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:45:32.009
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:45:32.009
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:45:32.009
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:45:32.009
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:45:32.009
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-09-13 18:45:32.009
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:45:32.009
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:45:32.009
DTC Client socket (2) | Closed. | 2020-09-13 18:45:32.009
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-09-13 18:46:02.024
DTC Client socket (2) | Creating socket. | 2020-09-13 18:46:02.026
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:46:02.026
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:46:02.057
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:46:02.057
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:46:02.057
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:46:02.122
SC Data - All Services | Sending logon request message. | 2020-09-13 18:46:02.122
SC Data - All Services | Received logon response. | 2020-09-13 18:46:02.748
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:46:02.748
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:46:02.748
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:46:02.748
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:46:02.748
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:46:02.748
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:46:02.748
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:46:02.748
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:46:02.748
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:46:02.748
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:46:02.777
DTC Client socket (2) | Closed. | 2020-09-13 18:46:02.777
HD Request # 5 | Downloading Intraday chart data for ESZ20_FUT_CME to the file ESZ20_FUT_CME.scid. Service: cme | 2020-09-13 18:46:31.985
Enabling compression for file: C:\SierraChart\SierraChartInstance_3\Data\ESZ20_FUT_CME.scid. This may take a while. | 2020-09-13 18:46:31.985
HD Request # 5 | Download start date-time: 2020-09-13 18:45:28.000 | 2020-09-13 18:46:31.985
HD Request # 5 | Using server: ds21.sierracharts.com port 10149 | 2020-09-13 18:46:31.986
Socket (2) | Creating socket. | 2020-09-13 18:46:31.986
Socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:46:31.986
HD Request # 5 | Setting DTC encoding to Binary VLS | 2020-09-13 18:46:32.056
HD Request # 5 | Sending historical data logon request message. | 2020-09-13 18:46:32.056
HD Request # 5 | Requesting Intraday data. Start date-time: 2020-09-13 18:45:28. Record interval: 0. Symbol: ESZ20 | 2020-09-13 18:46:32.536
HD Request # 5 | Decompressing data. | 2020-09-13 18:46:32.566
HD Request # 5 | Receiving Intraday data for ESZ20_FUT_CME starting at 2020-09-13 18:45:28.521000 | 2020-09-13 18:46:32.567
Socket (2) | CloseSocket call. | 2020-09-13 18:46:32.567
Socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:46:32.567
Socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:46:32.568
Historical data download thread signaled to stop. | 2020-09-13 18:46:32.568
HD Request # 5 | Timestamp of first Intraday data file record written: 2020-09-13 18:45:28.521001 | 2020-09-13 18:46:32.568
HD Request # 5 | Received 263 records from 2020-09-13 18:45:28.521 to 2020-09-13 18:46:30.164 (61.6 seconds) and wrote 263 records for ESZ20_FUT_CME | 2020-09-13 18:46:32.568
HD Request # 5 | Completion time: 1s | 2020-09-13 18:46:32.568
HD Request # 5 | Intraday data download complete for ESZ20_FUT_CME. Unique request ID: 5 | 2020-09-13 18:46:32.568
Removing historical data download ID 5. | 2020-09-13 18:46:32.568
Real-time Intraday chart data file updates started for ESZ20_FUT_CME | 2020-09-13 18:46:32.568
Intraday chart data file opened for ESZ20_FUT_CME | 2020-09-13 18:46:32.568
HD Request # 5 | Enabling Intraday chart updating for symbol. | 2020-09-13 18:46:32.568
Triggering next historical data download in queue. | 2020-09-13 18:46:32.568
Mapping ESU20_FUT_CME to ESU20. Service code: cme | 2020-09-13 18:46:32.568
HD Request # 6 | Downloading Historical Daily chart data for ESU20_FUT_CME. Starting date: 2020-09-10. Service: DTCSubInstance | 2020-09-13 18:46:32.569
HD Request # 6 | Using server: 127.0.0.1 port 11098 | 2020-09-13 18:46:32.569
Socket (3) | Creating socket. | 2020-09-13 18:46:32.569
Socket (3) | Connecting to IP: 127.0.0.1. | 2020-09-13 18:46:32.570
HD Request # 6 | Setting DTC encoding to Binary VLS | 2020-09-13 18:46:32.579
HD Request # 6 | Sending historical data logon request message. | 2020-09-13 18:46:32.579
HD Request # 6 | Requesting historical Daily data starting at 2020-09-10. | 2020-09-13 18:46:32.580
HD Request # 6 | Decompressing data. | 2020-09-13 18:46:32.581
HD Request # 6 | Receiving historical Daily data for ESU20_FUT_CME starting at 2020-09-10 | 2020-09-13 18:46:32.583
HD Request # 6 | Writing historical Daily data to the file ESU20_FUT_CME.dly | 2020-09-13 18:46:32.583
Socket (3) | CloseSocket call. | 2020-09-13 18:46:32.585
Socket (3) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:46:32.585
Socket (3) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:46:32.585
Historical data download thread signaled to stop. | 2020-09-13 18:46:32.585
HD Request # 6 | Received 3 records from 2020-09-10 00:00:00 to 2020-09-14 00:00:00 (5.0 days) and wrote 3 records for ESU20_FUT_CME | 2020-09-13 18:46:32.585
HD Request # 6 | Completion time: 0s | 2020-09-13 18:46:32.585
HD Request # 6 | Daily data download complete for ESU20_FUT_CME. Unique request ID: 6 | 2020-09-13 18:46:32.585
Removing historical data download ID 6. | 2020-09-13 18:46:32.585
Triggering next historical data download in queue. | 2020-09-13 18:46:32.585
Socket (3) | Socket gracefully closed by remote side. | 2020-09-13 18:46:32.585
Socket (3) | Closed. | 2020-09-13 18:46:32.586
Socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:46:32.599
Socket (2) | Closed. | 2020-09-13 18:46:32.599
ESZ20_FUT_CME [CV] 7 Day #3 | Download is complete for all contract months in chart. Proceeding with data load. | 2020-09-13 18:46:32.622
ESZ20_FUT_CME [CV] 7 Day #3 | Reloading chart. | 2020-09-13 18:46:32.622
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:46:32.761
DTC Client socket (2) | Creating socket. | 2020-09-13 18:46:32.762
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:46:32.762
Chart #1 has tagged chart #2 for full recalculation. Chartbook: HS_TPO.cht | 2020-09-13 18:46:32.762
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:46:32.793
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:46:32.793
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:46:32.793
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:46:32.848
SC Data - All Services | Sending logon request message. | 2020-09-13 18:46:32.848
ESZ20_FUT_CME [CV] 7 Day #3 | Reloading chart. | 2020-09-13 18:46:33.109
ESZ20_FUT_CME [CV] 7 Day #3 | Limiting the number of years to load data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:46:33.109
ESZ20_FUT_CME [CV] 7 Day #3 | Limiting the number of years to download historical data for to 10 years for the continuous futures chart. Reason: 10 years maximum for Intraday charts. | 2020-09-13 18:46:33.109
SC Data - All Services | Received logon response. | 2020-09-13 18:46:33.939
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:46:33.939
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:46:33.939
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:46:33.939
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:46:33.939
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:46:33.939
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:46:33.939
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:46:33.939
DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2020-09-13 18:46:33.939
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:46:33.939
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:46:33.939
DTC Client socket (2) | Closed. | 2020-09-13 18:46:33.939
ESZ20_FUT_CME [CV][M] #2 | Performing a full recalculation because it has been tagged. Chartbook: HS_TPO.cht | 2020-09-13 18:46:33.939
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2020-09-13 18:47:03.948
DTC Client socket (2) | Creating socket. | 2020-09-13 18:47:03.949
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:47:03.949
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:47:03.980
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:47:03.980
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:47:03.980
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:47:04.133
SC Data - All Services | Sending logon request message. | 2020-09-13 18:47:04.134
SC Data - All Services | Received logon response. | 2020-09-13 18:47:04.745
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:47:04.745
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:47:04.745
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:47:04.745
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:47:04.745
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:47:04.745
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:47:04.745
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:47:04.745
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:47:04.745
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:47:04.745
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:47:04.774
DTC Client socket (2) | Closed. | 2020-09-13 18:47:04.774
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2020-09-13 18:47:34.738
DTC Client socket (2) | Creating socket. | 2020-09-13 18:47:34.739
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:47:34.739
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:47:34.770
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:47:34.770
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:47:34.770
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:47:34.865
SC Data - All Services | Sending logon request message. | 2020-09-13 18:47:34.865
SC Data - All Services | Received logon response. | 2020-09-13 18:47:35.502
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:47:35.502
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:47:35.502
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:47:35.502
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:47:35.502
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:47:35.502
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:47:35.502
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:47:35.502
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:47:35.502
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:47:35.502
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:47:35.546
DTC Client socket (2) | Closed. | 2020-09-13 18:47:35.546
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2020-09-13 18:48:05.482
DTC Client socket (2) | Creating socket. | 2020-09-13 18:48:05.482
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:48:05.482
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:48:05.519
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:48:05.519
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:48:05.519
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:48:05.653
SC Data - All Services | Sending logon request message. | 2020-09-13 18:48:05.653
SC Data - All Services | Received logon response. | 2020-09-13 18:48:06.279
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:48:06.279
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:48:06.279
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:48:06.279
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:48:06.279
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:48:06.279
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:48:06.279
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:48:06.279
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:48:06.279
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:48:06.309
DTC Client socket (2) | Closed. | 2020-09-13 18:48:06.309
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:48:36.288
DTC Client socket (2) | Creating socket. | 2020-09-13 18:48:36.289
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:48:36.289
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:48:36.321
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:48:36.321
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:48:36.321
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:48:36.365
SC Data - All Services | Sending logon request message. | 2020-09-13 18:48:36.365
SC Data - All Services | Received logon response. | 2020-09-13 18:48:36.973
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:48:36.973
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:48:36.973
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:48:36.973
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:48:36.973
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:48:36.973
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:48:36.973
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:48:36.973
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:48:36.973
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:48:36.973
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:48:37.004
DTC Client socket (2) | Closed. | 2020-09-13 18:48:37.004
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-09-13 18:49:06.952
DTC Client socket (2) | Creating socket. | 2020-09-13 18:49:06.952
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:49:06.952
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:49:06.985
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:49:06.985
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:49:06.985
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:49:07.144
SC Data - All Services | Sending logon request message. | 2020-09-13 18:49:07.144
SC Data - All Services | Received logon response. | 2020-09-13 18:49:07.761
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:49:07.761
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:49:07.761
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:49:07.761
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:49:07.761
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:49:07.761
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:49:07.761
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:49:07.761
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:49:07.761
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:49:07.761
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:49:07.791
DTC Client socket (2) | Closed. | 2020-09-13 18:49:07.791
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:49:37.747
DTC Client socket (2) | Creating socket. | 2020-09-13 18:49:37.748
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:49:37.748
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:49:37.778
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:49:37.778
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:49:37.778
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:49:37.929
SC Data - All Services | Sending logon request message. | 2020-09-13 18:49:37.929
SC Data - All Services | Received logon response. | 2020-09-13 18:49:38.618
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:49:38.618
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:49:38.618
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:49:38.618
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:49:38.618
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:49:38.618
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:49:38.618
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:49:38.618
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:49:38.618
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:49:38.618
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:49:38.650
DTC Client socket (2) | Closed. | 2020-09-13 18:49:38.650
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-09-13 18:50:08.619
DTC Client socket (2) | Creating socket. | 2020-09-13 18:50:08.619
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:50:08.619
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:50:08.649
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:50:08.650
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:50:08.650
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:50:08.791
SC Data - All Services | Sending logon request message. | 2020-09-13 18:50:08.791
SC Data - All Services | Received logon response. | 2020-09-13 18:50:09.462
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:50:09.462
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:50:09.462
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:50:09.462
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:50:09.462
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:50:09.462
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:50:09.462
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:50:09.462
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:50:09.463
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:50:09.463
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:50:09.497
DTC Client socket (2) | Closed. | 2020-09-13 18:50:09.497
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:50:39.468
DTC Client socket (2) | Creating socket. | 2020-09-13 18:50:39.468
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:50:39.468
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:50:39.509
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:50:39.509
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:50:39.509
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:50:39.655
SC Data - All Services | Sending logon request message. | 2020-09-13 18:50:39.655
SC Data - All Services | Received logon response. | 2020-09-13 18:50:40.296
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:50:40.296
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:50:40.296
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:50:40.296
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:50:40.296
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:50:40.296
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:50:40.296
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:50:40.296
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:50:40.296
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:50:40.296
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:50:40.325
DTC Client socket (2) | Closed. | 2020-09-13 18:50:40.325
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-09-13 18:51:10.280
DTC Client socket (2) | Creating socket. | 2020-09-13 18:51:10.281
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:51:10.281
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:51:10.311
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:51:10.311
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:51:10.311
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:51:10.454
SC Data - All Services | Sending logon request message. | 2020-09-13 18:51:10.454
SC Data - All Services | Received logon response. | 2020-09-13 18:51:11.033
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:51:11.033
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:51:11.033
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:51:11.033
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:51:11.033
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:51:11.033
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:51:11.033
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:51:11.033
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:51:11.033
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:51:11.033
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:51:11.062
DTC Client socket (2) | Closed. | 2020-09-13 18:51:11.062
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:51:41.021
DTC Client socket (2) | Creating socket. | 2020-09-13 18:51:41.022
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:51:41.022
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:51:41.052
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:51:41.052
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:51:41.052
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:51:41.187
SC Data - All Services | Sending logon request message. | 2020-09-13 18:51:41.187
SC Data - All Services | Received logon response. | 2020-09-13 18:51:41.790
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:51:41.790
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:51:41.790
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:51:41.790
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:51:41.790
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:51:41.790
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:51:41.790
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:51:41.790
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:51:41.790
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:51:41.790
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:51:41.820
DTC Client socket (2) | Closed. | 2020-09-13 18:51:41.820
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-09-13 18:52:11.791
DTC Client socket (2) | Creating socket. | 2020-09-13 18:52:11.791
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:52:11.791
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:52:11.823
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:52:11.823
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:52:11.823
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:52:11.967
SC Data - All Services | Sending logon request message. | 2020-09-13 18:52:11.967
SC Data - All Services | Received logon response. | 2020-09-13 18:52:12.594
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:52:12.594
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:52:12.594
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:52:12.594
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:52:12.594
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:52:12.594
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:52:12.594
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:52:12.594
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:52:12.594
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:52:12.594
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:52:12.625
DTC Client socket (2) | Closed. | 2020-09-13 18:52:12.625
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2020-09-13 18:52:42.585
DTC Client socket (2) | Creating socket. | 2020-09-13 18:52:42.585
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:52:42.585
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:52:42.616
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:52:42.616
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:52:42.616
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:52:42.776
SC Data - All Services | Sending logon request message. | 2020-09-13 18:52:42.776
SC Data - All Services | Received logon response. | 2020-09-13 18:52:43.434
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:52:43.434
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:52:43.434
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:52:43.434
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:52:43.434
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:52:43.434
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:52:43.434
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:52:43.434
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:52:43.434
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:52:43.434
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:52:43.462
DTC Client socket (2) | Closed. | 2020-09-13 18:52:43.462
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2020-09-13 18:53:13.425
DTC Client socket (2) | Creating socket. | 2020-09-13 18:53:13.425
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:53:13.425
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:53:13.458
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:53:13.458
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:53:13.458
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:53:13.588
SC Data - All Services | Sending logon request message. | 2020-09-13 18:53:13.588
SC Data - All Services | Received logon response. | 2020-09-13 18:53:13.619
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:53:13.619
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:53:13.619
SC Data - All Services | Logon error received from server: Maximum connections reached. | 2020-09-13 18:53:13.619
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:53:13.619
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:53:13.619
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:53:13.619
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:53:13.619
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:53:13.619
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2020-09-13 18:53:13.619
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:53:13.649
DTC Client socket (2) | Closed. | 2020-09-13 18:53:13.649
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:53:15.612
DTC Client socket (2) | Creating socket. | 2020-09-13 18:53:15.612
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:53:15.612
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:53:15.641
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:53:15.641
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:53:15.642
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:53:15.738
SC Data - All Services | Sending logon request message. | 2020-09-13 18:53:15.738
SC Data - All Services | Received logon response. | 2020-09-13 18:53:16.347
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:53:16.347
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:53:16.347
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:53:16.347
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:53:16.347
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:53:16.347
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:53:16.347
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:53:16.347
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:53:16.347
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:53:16.347
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:53:16.392
DTC Client socket (2) | Closed. | 2020-09-13 18:53:16.392
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2020-09-13 18:53:46.345
DTC Client socket (2) | Creating socket. | 2020-09-13 18:53:46.346
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:53:46.346
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:53:46.377
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:53:46.377
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:53:46.377
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:53:46.533
SC Data - All Services | Sending logon request message. | 2020-09-13 18:53:46.533
SC Data - All Services | Received logon response. | 2020-09-13 18:53:47.159
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:53:47.159
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:53:47.159
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:53:47.159
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:53:47.159
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:53:47.159
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:53:47.159
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:53:47.159
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:53:47.159
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:53:47.159
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:53:47.189
DTC Client socket (2) | Closed. | 2020-09-13 18:53:47.189
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:54:17.163
DTC Client socket (2) | Creating socket. | 2020-09-13 18:54:17.163
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:54:17.163
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:54:17.195
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:54:17.195
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:54:17.195
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:54:17.238
SC Data - All Services | Sending logon request message. | 2020-09-13 18:54:17.238
SC Data - All Services | Received logon response. | 2020-09-13 18:54:17.879
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:54:17.879
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:54:17.879
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:54:17.879
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:54:17.879
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:54:17.879
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:54:17.879
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:54:17.879
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:54:17.879
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:54:17.879
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:54:17.908
DTC Client socket (2) | Closed. | 2020-09-13 18:54:17.908
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 10048 | 2020-09-13 18:54:47.873
DTC Client socket (2) | Creating socket. | 2020-09-13 18:54:47.873
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:54:47.873
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:54:47.905
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:54:47.905
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:54:47.905
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:54:47.962
SC Data - All Services | Sending logon request message. | 2020-09-13 18:54:47.962
SC Data - All Services | Received logon response. | 2020-09-13 18:54:48.573
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:54:48.573
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:54:48.573
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:54:48.573
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:54:48.573
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:54:48.573
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:54:48.573
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:54:48.573
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:54:48.573
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:54:48.573
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:54:48.604
DTC Client socket (2) | Closed. | 2020-09-13 18:54:48.604
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:55:18.560
DTC Client socket (2) | Creating socket. | 2020-09-13 18:55:18.560
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:55:18.560
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:55:18.591
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:55:18.591
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:55:18.591
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:55:18.645
SC Data - All Services | Sending logon request message. | 2020-09-13 18:55:18.645
SC Data - All Services | Received logon response. | 2020-09-13 18:55:19.267
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:55:19.267
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:55:19.267
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:55:19.267
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:55:19.267
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:55:19.267
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:55:19.267
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:55:19.267
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:55:19.267
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:55:19.267
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:55:19.296
DTC Client socket (2) | Closed. | 2020-09-13 18:55:19.296
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-09-13 18:55:49.250
DTC Client socket (2) | Creating socket. | 2020-09-13 18:55:49.250
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:55:49.250
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:55:49.282
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:55:49.282
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:55:49.282
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:55:49.352
SC Data - All Services | Sending logon request message. | 2020-09-13 18:55:49.352
SC Data - All Services | Received logon response. | 2020-09-13 18:55:49.992
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:55:49.992
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:55:49.992
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:55:49.992
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:55:49.992
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:55:49.992
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:55:49.992
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:55:49.992
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:55:49.992
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:55:49.992
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:55:50.021
DTC Client socket (2) | Closed. | 2020-09-13 18:55:50.021
SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2020-09-13 18:56:19.984
DTC Client socket (2) | Creating socket. | 2020-09-13 18:56:19.984
DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2020-09-13 18:56:19.984
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:56:20.015
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:56:20.015
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:56:20.015
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:56:20.124
SC Data - All Services | Sending logon request message. | 2020-09-13 18:56:20.124
SC Data - All Services | Received logon response. | 2020-09-13 18:56:20.779
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:56:20.779
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:56:20.779
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:56:20.779
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:56:20.779
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:56:20.779
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:56:20.779
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:56:20.779
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:56:20.779
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:56:20.779
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:56:20.811
DTC Client socket (2) | Closed. | 2020-09-13 18:56:20.811
SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2020-09-13 18:56:50.789
DTC Client socket (2) | Creating socket. | 2020-09-13 18:56:50.789
DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2020-09-13 18:56:50.789
SC Data - All Services | Network connection to server complete. | 2020-09-13 18:56:50.820
SC Data - All Services | Starting socket receive thread. | 2020-09-13 18:56:50.820
SC Data - All Services | Sending encoding request to server: Binary VLS | 2020-09-13 18:56:50.820
SC Data - All Services | Setting DTC encoding to Binary VLS | 2020-09-13 18:56:50.892
SC Data - All Services | Sending logon request message. | 2020-09-13 18:56:50.892
SC Data - All Services | Received logon response. | 2020-09-13 18:56:51.455
SC Data - All Services | Server Name: SC Real-Time Server. | 2020-09-13 18:56:51.455
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2020-09-13 18:56:51.455
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 2, NumCurrentConnectionsForSameDevice = 3 | 2020-09-13 18:56:51.455
SC Data - All Services | Waiting for socket receive thread to end | 2020-09-13 18:56:51.455
DTC Client socket (2) | CloseSocket call. | 2020-09-13 18:56:51.455
DTC Client socket (2) | 0 bytes remaining in receive buffer when socket closed. | 2020-09-13 18:56:51.455
DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2020-09-13 18:56:51.455
SC Data - All Services | Disconnected from the server. | 2020-09-13 18:56:51.455
SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2020-09-13 18:56:51.455
DTC Client socket (2) | Socket gracefully closed by remote side. | 2020-09-13 18:56:51.485
DTC Client socket (2) | Closed. | 2020-09-13 18:56:51.485
Date Time Of Last Edit: 2020-09-14 00:52:53
[2020-09-14 11:09:13]
This has already been resolved.
