Date/Time: Tue, 11 Feb 2025 14:37:23 +0000
Closing open positions - match filled quantity
View Count: 719
[2020-09-11 11:11:26]
User495158 - Posts: 108
I trade using a DOM.
Lets say I put in a 10 lot limit buy order. I get filled 6.
I would like to close this position with a limit sell order at the offer (of 6 lots). But instead of manually adjusting the quantity, or having a bunch of quantity presets, I would like to do it with a single mouse click on the DOM. Something like flatten, but a limit order.
Is it possible to do this?
[2020-09-11 14:05:00]
John - SC Support - Posts: 37869
Refer to the following information for setting up the mouse actions to enact specific trade types:
Global Trade Settings Windows: Chart DOM Settings
But note that you will have to manually set the quantity prior to placing the order.
[2020-09-13 00:45:21]
You really need to do a Flatten operation, there is no other safe way. However, you can set up a keyboard shortcut for it.
Date Time Of Last Edit: 2020-09-13 00:45:33
