Date/Time: Tue, 11 Feb 2025 14:39:59 +0000
Issue with Clear Trade Simulation Orders & Data
View Count: 563
[2020-09-11 08:19:43]
sugart - Posts: 25
When this option is selected, it does not clear "Trade Simulation Orders & Data".
Thanks.
[2020-09-11 09:57:12]
It does function properly. However, we do notice that you do need to manually update the Trade Activity Log by pressing the Apply button to see the activity is cleared.
Also refer to:
Trade Activity Log: Trade Activity Not Displaying or Clearing (Improving Trade Activity Query Performance)
The above section describes another problem you might be encountering.
Date Time Of Last Edit: 2020-09-11 09:57:29
[2020-09-12 09:22:37]
sugart - Posts: 25
I used this step, as mentioned on SierraChart online help:
"To quickly clear all the Simulated Order and Fill activity for all Symbols and all simulated Trade Accounts from the Trade Activity Log, select Trade >> Clear Trade Simulation Orders and Data".
I cannot see any "Apply" option.
[2020-09-13 02:56:25]
Yes but how do you know this command is not working? What is it that you are seeing that causes you to come to that conclusion.
Date Time Of Last Edit: 2020-09-13 02:56:37
