Date/Time: Sun, 04 Oct 2026 09:40:50 +0000
ACSIL Contract Rollover
View Count: 1382
| [2020-09-10 14:51:40] |
| User92573 - Posts: 617 |
Dear Support Forum In "studies2.cpp" I have found the following: SCSFExport scsf_RolloverDateDisplay(SCStudyInterfaceRef sc)
SCString DateString ("Rollover: "); DateString += sc.DateToString(sc.ContractRolloverDate); However I'm having trouble working out how to structure an ACSIL study so that I can access the current rollover date in the Tool Value Windows as opposed to it being a label/study on the chart itself. Any assistance gratefully received. Many thanks |
| [2020-09-15 09:39:43] |
We have this documentation available: ACSIL Interface Members - Variables and Arrays: sc.ContractRolloverDate And we really do not understand the question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-09-16 15:40:27] |
Yes, I know but I've been unable to use/implement it. Hence I was hoping for some forum assistance. ACSIL programming has been advancing well but for some reason I'm stumbling here. Many thanks. Date Time Of Last Edit: 2020-09-16 15:41:01
| [2020-09-16 19:07:05] |
Stumbling with what specifically? The documentation is there and you have an example. If you are having difficulty with this, we recommend hiring a programmer.
| [2020-09-17 06:12:43] |
Okay I'll do that. I've got on very well with ACSIL study programming but for some reason I'm having difficulty storing the rollover string in an array. I suppose it should be as a persistent variable. I'm spending more time going through C++ and getting there slowly but still obviously stumble here and there. Thank you for taking the time to reply SC is really an amazing product and I've used a lot of platforms over some 25 years - but as a trader opposed to a programmer. Many thanks. Date Time Of Last Edit: 2020-09-17 06:13:55
| [2020-09-17 17:34:17] |
What array are you trying to store it in? It would have to be an array of strings.
