Date/Time: Tue, 11 Feb 2025 13:53:16 +0000
Simultaneous connection
View Count: 455
[2020-09-10 08:05:13]
Albamail - Posts: 29
Hi
Is it possible to simultaneously connect, for example, CME data (Rithmic) and BitMEX data?
[2020-09-11 09:47:03]
Not sure we support BitMex data with Rithmic. But what you can do instead is install another installation of Sierra Chart to access BitMex data. Refer to:
Using Multiple Data and Trading Services at the Same Time
And refer to:
Cryptocurrency / Bitcoin Data and Trading Services
Date Time Of Last Edit: 2020-09-11 09:47:32
