Date/Time: Tue, 11 Feb 2025 13:44:30 +0000
SIM/Live Mode
View Count: 994
[2020-09-09 16:49:03] |
Mattc55 - Posts: 97 |
Hello, Is it possible to remain in the live trading environment, but trade a particular market in SIM and another live? Ideally, I'd like to be able to trade MES live and CL SIM without having to switch into global sim mode. My drop down menu to select accounts only shows my live account and not the SIM account. I could be wrong, but a while back i thought that I once had the ability to toggle between the two, while remaining outside the global sim mode. thanks |
[2020-09-09 20:37:22] |
To do this you will need to use a separate instance of Sierra Chart and have one be live and the other in Trade Simulation mode. Refer to the information here: Trade Simulation: Using Trade Simulation Mode and Live Trading at Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-09 20:38:26
