Date/Time: Tue, 11 Feb 2025 13:49:58 +0000
HSI Futures ~ Hong Kong Future Exchange
View Count: 1343
[2020-09-09 16:48:46] |
TOMKKLAW240418 - Posts: 2 |
Just want to know HSI (Hang Seng Index Future) real time data is available or not. Thanks |
[2020-09-09 20:18:04] |
User13668 - Posts: 294 |
Depends on who your broker is and what data feed you are using. I am with AMP Futures (USA) using CQG data and I trade Live the HKFE markets (mainly HSI). |
[2020-09-09 20:36:41] |
Yes, this is available through the Sierra Chart Exchange Data Feed and then enabling the Hong Kong Futures Exchange. Refer to the documentation here: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
