Date/Time: Mon, 25 Nov 2024 10:39:55 +0000
One connection per user name
View Count: 1079
[2014-02-05 13:59:59] |
User88901 - Posts: 33 |
Hi, I am logged onto Interactive Brokers and Sierra charts at my house but I am at my office now and it is saying one connection per user name. DTN IQ would force log out my home connection when I went to office but I guess this one cannot?
[2014-02-05 14:08:32] |
I don't know if I made it clear but I am using the SC data feed through IB on both computers.
[2014-02-05 17:21:51] |
The Sierra Chart Real-time Data Feed will not disconnect an existing connection to it if you try to use it from another instance of Sierra Chart. Instead which you need to do is add a second connection. This can be done here: https://www.sierrachart.com/usercp.php?page=Features Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
