Date/Time: Tue, 11 Feb 2025 14:00:23 +0000
smooth orderflow (up tick down tick)
View Count: 713
[2020-09-09 14:29:10]
MarcOh - Posts: 163
Hi guys,
last days sierra chart seems to be little jerky. the order flow seems kinda ticked off. Like in the replay mode. Its not working very smooth.
Could this be a rithmic (MES capital) issue?
Im using WIN 10. 3,4ghz Intel, 16RAM and I didnt change anything. Using current version.
By the way: In love with sierra from day one on and also using denaly ;). Just sayin.
Best regards.
Marco
Date Time Of Last Edit: 2020-09-09 14:29:53
[2020-09-09 20:28:49]
Refer to the information here:
Prices / Data Falling Behind
And check the Chart Update Interval:
Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu)
[2020-09-09 21:15:06]
MarcOh - Posts: 163
I will. Thx a lot! (chart update is always set to 10. I know it doesnt makes sense between 40 and 10, but I will check the whole instruction).
thank you
Marc
