Date/Time: Mon, 25 Nov 2024 10:55:27 +0000
TT Positions Through Rollover
View Count: 1058
[2014-02-05 13:58:58] |
vegasfoster - Posts: 444 |
Hi, I would like my positions to carry through the daily rollover on the chart trader, can you please tell me where to find the following settings or the current way to accomplish the same? "Global Settings >> Trade Settings" and uncheck "Synchronize Service and Internal Positions on Connect" and "Use Internal Position for Charts, Trading DOMs, Flatten and Reverse" Taken from this post, http://www.sierrachart.com/supportboard/showpost.php?p=206072&postcount=2 I'm sure I'm blind, but I've looked at the general, |
[2014-02-05 17:23:39] |
You need to use the Order Fill calculated Position. It is documented here: http://www.sierrachart.com/index.php?l=doc/doc_TradeStatusWindows.html#OrderFillCalculatedPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-05 18:17:57] |
I looked at a bunch of stuff, thank you.
