Date/Time: Tue, 11 Feb 2025 13:57:33 +0000
Nasdaq Issue
View Count: 597
[2020-09-09 13:34:50] |
User725605 - Posts: 60 |
I trade intraday charts with separate chartbooks for ES Cl GC and Nasdaq. All days back, number of charts, and settings are the same across all of these separate chartbooks. As I scroll through the individual charts for ES Cl GC the scroll wheel on my mouse or my left click mouse pointer, or if I have to move ie. a trendline,or the slider on the bottom of the chart, all is easy and smooth. On my Nasdaq chartbook, and on any individual Nasdaq charts, any mouse action is very stunted, herky jerky, and difficult to say the least. I have re-created a new chartbook for the Nasdaq with no positive change. Please advise a fix. Thank you. |
[2020-09-09 20:02:00] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Could be due to this but other reasons as well: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.26 - Too Many Chart Drawings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-09 20:02:39
