Date/Time: Tue, 11 Feb 2025 14:50:36 +0000
Source code for custom studies leaked
View Count: 927
[2020-09-09 07:25:34]
User383849 - Posts: 23
Hi!
I'm having an issue where if I copy the .dll file to my clients, the .cpp (source) file will be generated after they restart SC.
I manage to recreate this issue each time.
I'm also using the "Enable/Disable users for your Custom Studies" feature.
Pls advice. Thks!
[2020-09-09 07:54:35]
The problem is you uploaded the source code here:
https://www.sierrachart.com/UserControlPanel.php?page=SetFileGroupsForCustomStudies
Remove those CPP files.
[2020-09-09 08:02:37]
Thanks! So I should only upload the .dll
Can I just upload the 64 bit version considering none of my clients are on 32 bit platform?
[2020-09-09 19:49:00]
Yes that is correct. Just the 64-bit one is sufficient.
[2020-09-12 22:38:45]
ForgivingComputers.com - Posts: 1001
Note that this will only prevent the cpp files from downloading in the future. Any copies that were previously downloaded will not be removed unless each of your clients removes them.
