Date/Time: Tue, 11 Feb 2025 13:47:15 +0000
same chart side x side, markep profile spaced out what gives?
View Count: 528
[2020-09-09 01:10:06]
HeyUgly - Posts: 251
hello
pic attached, this is really bugging me. my friend and i use the same chartbook, using a mrket profile, exact same. His is nice and tight, my letters have these gaps inbetween them, like they are spaced out, how do i get rif of this? even if i collapse the profile i still have these gaps
thank you in advance
imageYO.PNG / V - Attached On 2020-09-09 01:09:43 UTC - Size: 134.08 KB - 212 views
[2020-09-09 14:49:14]
John - SC Support - Posts: 37869
It is just a matter of the chart spacing. If you shorten the spacing (page down key) then the spacing will get smaller. Refer to the information here:
Time Price Opportunity (TPO) Profile Charts: Scaling the TPO Profile Chart
