Date/Time: Tue, 11 Feb 2025 13:51:44 +0000
Best brokerage compatible with Sierra?
View Count: 919
[2020-09-08 22:25:44] |
CLscalper - Posts: 28 |
Lots of post's about brokerages that aren't favorable with Sierra: Can you please list two or three brokerage's that work well with Sierra for day trading the NQ market (U.S. session)? Thanks in advance. |
[2020-09-09 20:35:56] |
We do not make specific brokerage recommendations, but we do recommend that you use the Sierra Chart Order Routing Service with Data. If you are interested in this, then refer to the partial list of Brokerages that support the service at Step #2 of the Setup Instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
