Date/Time: Tue, 04 Nov 2025 18:18:12 +0000
1 Hour chart
View Count: 2252
| [2013-04-17 16:36:56] |
| User88901 - Posts: 33 |
Hi I am trying to get a 1 or 2 hour chart of regular trading hours in #ES or SPY that goes back at least 2 months but I cannot seem to do it. Also how do I get a regular trading hours Spy Daily chart. I have one but its not RTH. I have IB data. Thanks.
| [2013-04-17 16:54:18] |
1. For the first request, this is difficult with Interactive Brokers and we cannot help with it. We assume you already know how to set the time frame of the chart bars and you know how to set the Session Times to the time range that you want, and you only have trouble with historical data. 2. You need to enable Global Settings >> Data/Trade Service Settings >> More Interactive Brokers Settings >> Download Regular Trading Hours Bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
