Date/Time: Tue, 11 Feb 2025 13:16:52 +0000
DOM Custom setting export between two computers
View Count: 504
[2020-09-08 18:59:21] |
User208416 - Posts: 39 |
Hi, I have a custom DOM setting on my laptop. Is there a way to export the custom setting from my laptop to my desktop ? how can i do that Thanks |
[2020-09-08 20:54:39] |
Refer to this help topic: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
