Date/Time: Tue, 11 Feb 2025 13:41:31 +0000
Extended POC after the Profile
View Count: 604
[2020-09-08 16:36:06] |
User158665 - Posts: 44 |
Is it possible for the Point of Control to be extended from the the last bar position (just like Extend Close Until Future Intersection) and not on the entire day session? I would like to display it after its profile and not on the entire day. Maybe there is a way and I am not finding it. (pic is attached). |
[2020-09-08 20:53:51] |
What you are asking for is not supported.
