Date/Time: Tue, 11 Feb 2025 13:16:14 +0000
FLATTEN keeps opening new position
View Count: 673
[2020-09-08 16:24:56] |
User889653 - Posts: 7 |
For several days every time I Flatten a working order, a new order automatically opens. I'm in Sim mode because I'm worried this issue will persist Live. In effect I always have a position opened, and cannot completely close all positions. If I open my trade orders window or trade positions window, there is nothing there, but each time I open a new position that previously flattened (now opened) position is closed at the same price my new order is opened. I then flatten the new order, which works, but a new position is then opened at the price flattened. Can anyone tell me how to fix this? How to Flatten all positions without automatically opening a new one.
[2020-09-08 18:47:33] |
Are you using Trade Simulation Mode?: Trade Simulation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-08 19:18:15] |
Yes using simulation mode. I don’t want to trade live if there is any chance that this issue will also be present there
[2020-09-09 19:29:14] |
So you have Trade >> Trade Simulation Mode On enabled?
