Date/Time: Tue, 11 Feb 2025 13:39:28 +0000
Maximum position allowed with multiple strategies
View Count: 458
[2020-09-08 13:41:28] |
MattK - Posts: 42 |
Hi, I have a quick question regarding the sc.MaximumPositionAllowed variable. I have multiple strategies running at the same time and I just put sc.MaximumPositionAllowed in one of them (the first in the list of studies). Do I need to add it to all strategies to avoid the variable being reset to 1? Thanks in advance. |
[2020-09-08 20:01:52] |
You would need to use it for each individual trading study because it only applies to an individual trading study.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-08 20:01:59
