Date/Time: Mon, 21 Sep 2026 10:02:02 +0000
dll name for higher versions
View Count: 764
| [2020-09-08 13:11:47] |
| User255315 - Posts: 133 |
Hi SC, I was in the middle of developing a new system so hadnt updated to the latest version since a while. I recently updated one of my installations and also placed the recompiled dll's in the new versions data folder but they are still giving me the recompilation message. I went through the locked post regarding the versions and have made changes in my code to account for constants, however the issue persists. What am i missing here The issue persists even if i do a remote build using the sierra application. Date Time Of Last Edit: 2020-09-08 13:17:05
| [2020-09-08 19:23:28] |
This is not making any sense to us at all. Furthermore no one is reporting something like this and it would not be reproducible under any condition. If you use Remote Build within a particular installation Sierra Chart the generated DLL is going to match. So what is it you are doing wrong? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-09-08 19:24:52
