Date/Time: Tue, 11 Feb 2025 13:17:11 +0000
Indicator not display on chart
View Count: 555
[2020-09-08 12:23:29]
gfx2trade - Posts: 48
Hi team,
I just completed a trading system using a few indicators.
My issue is that when I start the system, the indicator values are not yet or partially calculated (e.g ATR 10 value is not yet based on the last ten candles)
Indeed, as you can see on the screen, calculation and display start when system is turned on. Therefore, first ordre entries are incorrect.
I was expecting, using autoloop = 1 that indicators would be fully calculated and displayed on chart as soon as the study is placed on it.
Thanks in advance for your help.
Gfx.
imageDelayedIndic.JPG / V - Attached On 2020-09-08 12:22:53 UTC - Size: 26.89 KB - 209 views
imageDelayedIndic.JPG / V - Attached On 2020-09-08 12:23:22 UTC - Size: 26.89 KB - 226 views
[2020-09-08 19:43:21]
We really do not fully understand what you are trying to point out, but it sounds like it may be an order of calculation issue. If you have an automated trading system that is dependent on the results of other studies, then it needs to be at the bottom of the list of studies. Refer to the information here:
Chart Studies: Study Calculation Precedence And Related Issues
You really are going to have to figure this out yourself. It is not something we can understand what the issue is from our perspective.
Date Time Of Last Edit: 2020-09-08 19:55:25
