Date/Time: Fri, 07 Feb 2025 14:39:45 +0000
extension lines
View Count: 1154
[2020-09-08 11:30:52] |
User12089 - Posts: 365 |
the Color Bar based on Alert Condition study doesnt seem to be drawing extension lines from the colred bar when the condition is met and the bar colored
[2020-09-08 14:20:43] |
John - SC Support - Posts: 37808 |
Mostly likely what you are seeing is that the Extension Line is at some value that is not displayed in the chart (probably 0). Note that the Extension lines are drawn at the color bar value. Refer to the information here: Color Bar Based on Alert Condition: Draw Extension Lines at Color Bar Value For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-09-08 14:47:54] |
the setting "Draw Extension Line at Color Bar value" is set to Extend to End of Chart
[2020-09-08 14:55:23] |
The price level at which the lines are drawn is based on the Output when Condition is True input. Make sure that this is set to a value where you want to see the lines. Refer to the information here for this item: Color Bar Based on Alert Condition: Output When Condition Is True For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
