Date/Time: Tue, 11 Feb 2025 13:17:11 +0000
VWAP
View Count: 517
[2020-09-08 10:29:38]
User498170 - Posts: 2
Hello.
I want to display two VWAPs, one which calculates the overnight transfer and one which calculates the cash transfer.
Can you tell me what settings to do?
Thank you
[2020-09-08 14:16:45]
John - SC Support - Posts: 37869
You would have to have two different charts with the appropriate Session Times for each item that you want then add the VWAP study to each chart. Refer to the information here for Session Times:
Chart Session Times
If you just want to view the VWAP's most recent value, then you can use the Text Display for Study from Chart study to display the VWAP information on another chart. Refer to the information here:
Text Display For Study from Chart
